JD 1050 chg lite stays on
cdv
12-26-2007 17:26:36
my 1st JD got it 2 weeks ago put a new battery in it,but the chg lite on the dash is on,put my meter on batt and run the engineand meter reads 14.9-to15,try running full throttle still won;t go off am I missing something thanks cdv
machinery-man
12-27-2007 04:01:35
 Re: JD 1050 chg lite stays on in reply to cdv, 12-26-2007 17:26:36
you want go many places without a service manual, operator's manual, parts manual. All the parts on these tractor are very very expensive and one cannot afford guesswork. My thoughts are lack of alternator output. It could be in the fuses but more than likely deeper problem, bad alternator, regulator. Current goes through the light and when charge goes to ground through the battery it shuts down the light. I've seen some parts on ebay but like previously stated JD parts are very expensive but I'd never try to jury rig. Fix it right and you'll be happy with the service. Tough little tractors....abuse and neglect was their biggest enemy
MSM
12-27-2007 00:06:07
Could be a bad diode in the alternator. It will still charge but the light will be on,but might also drain the battery when it sits. Another thing to check is the fuses,sometimes if one of them blows it will light the charge light.
