JD 6 cyl. cracked head
Josh Biffar
12-26-2007 07:50:20
I have a 1970 john deere 5020 that I bought cheap. One cylinder was rusted tight, been sitting for years. I"m overhauling the engine and took the head to a machine shop and found cracks on almost every injector port and in between all but one valve seat. Is this common on the 531 engine? They told me that they didn"t have much experiance with this type of head, said that possably was not a problem, might just be surface cracks but would not know for sure until more inspection was done. Is some cracks not that big a deal? Any help is very much appreciated!
RobMD
12-26-2007 16:33:19
 Re: JD 6 cyl. cracked head in reply to Josh Biffar, 12-26-2007 07:50:20
tons of parts 5020's.
Contact 2 cylinder plus tractor salvage out of conway, missouri.
buickanddeere
12-26-2007 12:10:04
Might be able to find a good running 619T out of a forage harvester. No more oil pump worries either.
Kent Petersen
12-26-2007 09:04:04
The type of cracks you have a the result of engine overheating best to find a good used head lots of salvage yards west of missippi river best area to look do not try to weld it later deere casings are alloyed and just crack out from edge of weld good luck Kent
