1010 special rear rims
CarlF
12-26-2007 07:25:51
since i am having such a difficult time finding rear rims for my tractor does anyone here know if rims from a another model tractor will fit?
i have a 2 piece rear rim. i noticed there are many different varations of rims on the 1010 model.
some 2 piece and some 1 piece.
i am locted in NJ.. if anyone has rims that would work please let me know.
CarlF
12-27-2007 03:52:07
 Re: 1010 special rear rims in reply to CarlF, 12-26-2007 07:25:51
awesome and thank you very much..
CarlF
12-26-2007 13:33:27
what about the center section?? the outer section i can find but it is the center part that i am having issues.
the outer rim i can find aftermarket, i think the ford tractors used the same style rim..
would you happen to have a part number??
thanks..
Ten-Twenty
12-26-2007 19:16:59
 Re: 1010 special rear rims in reply to CarlF, 12-26-2007 13:33:27
Carl,
You will have to ask your JD dealer if the specs are the same for that center disk which sure looks the same as the one on the 1020. The part numbers for the 24" and 28" centers on the 1020 LU and RU are T19638 ($165.00) and T19065 ($180.00), respectively.
CarlF
12-26-2007 12:15:07
here is a pic of the tractor.
third party image
Ten-Twenty
12-26-2007 13:17:59
 Re: 1010 special rear rims in reply to CarlF, 12-26-2007 12:15:07
Carl,
Those are very common 6-loop rims and they are still available from Deere and others in 24" and 28"sizes, priced at just over $200.00 each.
old
12-26-2007 09:37:55
Well if you wheren't so far away I have one good rim and tire off a 1010 but your about 1500 miles from me. If you have the power adjust type ones made for the Allis WD, WD45 and D-17 will fit just fine
