JD 50 carb help
JDman21
12-23-2007 14:22:36
What are the settings of each needle on the carb. on my 50? Also which needle is which. What is the big needle type thing on the bottom of the bowl where the nut is to tighten the bowl. And does that have to be set at something.
Thanks
JDman21
12-25-2007 07:55:08
 Re: JD 50 carb help in reply to JDman21, 12-23-2007 14:22:36
Was working on my tractor a while yesterday and found that my exhaust manifold gasket is gone and I can see between the manifold and the tractor where the gasket is supposed to be. Also brether tube hose was loose. Did some work on the carb. Starts good. Do you think once I get that gasket replaced that will make a difference?
Thanks for the help
machinery-man
12-24-2007 05:05:22
the adjustment at the bottom is altitude compensating valve. Sounds like you're just starting on these tractors. Personally I would recommend that you get manuals and also some instructions on repairs/service. All the parts especially the carburator are items where you can't afford to chance with guess work. Duplex carbs are now in the hundreds. Robert's carburator has good guides and parts. Merry Christmas
Earl - IL
12-23-2007 18:04:47
Flot l2- Idle needle 1 1/2 turn. Btm of bowl, high speed - load needle 2 1/2 turns . Each tractor will vary. This is just a starting point.You need a tachometer to fine tune the idle. By shorting plug on each side and adjust to max rpm.
buickanddeere
12-24-2007 07:22:58
 Re: JD 50 carb help in reply to Earl - IL, 12-23-2007 18:04:47
Adjusting to max rpm was fine 50 years ago. Today it wastes fuel and increases the tendency to foul plugs. The idle screws need to be backed off at least 1/4 to 1/2 turn from fastest idle speed.
Earl - IL
12-24-2007 08:21:13
 Re: JD 50 carb help in reply to buickanddeere, 12-24-2007 07:22:58
This worked good 50 yrs ago & it still works good today as much as it is a good starting point.I stated each tractor will vary on adjustment. I think if I was to lean down a little I would screw the idle needle 1/4 - 1/2 turn IN after I did the max rpm adjustment . Is that what you meant by backing them off? Dirty aircleaners .Not bringing up to temp. when they run their 50 yr old tractor. The fuel today isn't the same . Spark plugs aren't the same.
buickanddeere
12-24-2007 18:29:46
 Re: JD 50 carb help in reply to Earl - IL, 12-24-2007 08:21:13
I intended to say lean the idle screws after finding peak rpm by turning them in a 1/4 to 1/2 turn. Todays unleaded gasoline burns cleaner than anything leaded sold from the 1950's to 1980's. Certainly a restriction anywhere from the air intake snorkel to the top of the aircleaner's mesh is trouble. Coolant temps less than 195F don't let the engine run clean either.
Earl - IL
12-25-2007 17:59:15
 Re: JD 50 carb help in reply to buickanddeere, 12-24-2007 18:29:46
MERRY CHRISTMAS----- -HAPPY NEWYEAR Keep those PUTT, PUTTS running. Earl In Illinois
