1010 timing
Tony T.
12-23-2007 08:20:08
I recently bought a RU 1010....It needs a tune-up...The page pertaining to timing has been torn and partially missing (page 55+56 in my manual).. If someone could scan and email, or email instructions it would be greatly appreciated!!
Thanks up front
Tony T.
Loren NC
12-25-2007 08:27:54
 Re: 1010 timing in reply to Tony T., 12-23-2007 08:20:08
While you are working to make it run right, try this also. I had continuing problems making mine run after I bought it until I discovered the in-line fuel filter. Take the fuel line out of the carb, then remove the fitting that it went into. Turns out that is a screen. On mine it was COMPLETELY plugged with what looked like fuzz of some sort. Cleaned it out and the tractor suddenly decided to run much better.
Vermont John
12-24-2007 06:00:00
Perhaps you guys can help me. I bought a 1010 that they said was "tired" and had low compression. It also fouled plugs badly. I tested the compression and it ranged from 125 to 115 p.s.i., which is adequate. Turns out the timing was set to TDC. I have a mark on the flywheel that seems to read "16," rather than "26." When set there, it runs much better. Should I advance more?
Tony T.
12-24-2007 07:44:53
 Re: 1010 timing in reply to Vermont John, 12-24-2007 06:00:00
Interesting...Since I do not have any answers, I'll be watching for the replies also.
Tony T.
jdemaris
12-23-2007 12:09:40
third party image
third party image
third party image
Tony T.
12-23-2007 12:57:22
 Re: 1010 timing in reply to jdemaris, 12-23-2007 12:09:40
Thanks again!!
Tony T.
