John Deere D mag.
bigtim72
12-23-2007 05:55:09
just about have 1932 John deere D put back together motor wise but now i need to time the base mount mag my manual tells how to time a flange type mag but not a base mount is it about the same? it says to mount the flange type then rotate mag all the way in oppisate direction the turn flywheel one turn then tap mag till it fires the left cylinder is there a way to mount base mount mag and tap it till it fires the left cylinder? thanks for any instructions or help bigtim
Duane Larson
12-23-2007 10:22:18
 Re: John Deere D mag. in reply to bigtim72, 12-23-2007 05:55:09
bigtim72,
Time is short - ready to eat dinner, so copying an earlier description from Glen in Texas in the archives: Timing mag for D #30400-109943: 1. Have the mag secure to engine mounting and need 1/32" clearance between mag drive and float coupling. 2. Loosen the 2 clamps on mag engine drive flange to allowing mag to turn freely. 3. Turn engine in direction it runs to compression stroke on LH cylinder (flywheel side) with mark on flywheel "L.H. Ret. Spk." in line with the arrow or mark on cover. 4. Remove breaker cover and dist. cap on mag. 5. Set spark lever clear back (fully retarded spark). 6. Turn magneto same direction as flywheel runs until brass segment on distributor disc is in upper right hand corner and breaker points are just beginning to open. 7. Tighten 2 bolts on mag drive flange. 8. Spark plug wire from forward mag terminal goes to LH spark plug and rear one to RH spark plug. 9. Then check the impulse trip by turning flywheel back 1/2 turn and if mag has manual impulse trip you will have to set it to trip. Then rotate engine slowly forward and impulse should trip or click as mark on flywheel lines up with mark on cover and LH spark plug should fire. If not loosen drive flange bolts and if trip is early turn magneto opposite direction engine runs. If late turn mag same direction as engine runs and recheck until you get mark to line up. If that doesn't get you in time then you could have mag impulse problems or need to time the camshaft properly. Good luck.
John T
12-23-2007 08:07:29
Not being a D Man and until Duane gets here to explain it in detail and/or correct my errors, on those base mount mags since you cant rotate the mag in its flange mounting you INSTEAD rotate the coupler assembly (to turn the mags drive) by loosening its bolts n rotate it which accomplishes the same thing.
When you rotate a flange mount mag youre turning its drive shaft while the flywheel stays in place so on the base mount you again rotate/time the mag shaft (by adjusting the drive coupler) while the flywheel stays put.
On some of those Edison or Dixie Mags etc that have the adjustable spark advance lever and the different flywheel timing mark then the more typical left hand impulse (TDC) timing mark IM OUT TO LUNCH and am gonna attend Duanes Mag workshop next march at GOG
John T
