52 B Gasket Thickness
RonRod
12-23-2007 05:24:33
Would anyone know what gasket thickness should be used for the left main bearing housing and cover on a 1952 B. I forgot to order them (bearing cover gasket N/A from Deere) and hope to reassemble the crank and block when down at the farm for Christmas. Part numbers are B3026R and B2467R. Many thanks and Merry Christmas. Have a wonderful 2008.
Ron
jdhbag
12-23-2007 17:34:11
 Re: 52 B Gasket Thickness in reply to RonRod, 12-23-2007 05:24:33
I have a B2467R in my hand that measures .026
F-I-T
12-23-2007 18:25:52
 Re: 52 B Gasket Thickness in reply to jdhbag, 12-23-2007 17:34:11
Not sure that the cover gasket would make much difference as to thickness. It really doesn't control anything like a thrust shim. It just seals back oil, but glad you had one to measure.
Mike M
12-23-2007 10:27:19
It's always a good idea to save the old pieces so you can measure them. Only gaskets that really matter are the gov. gasket for the housing to case I think I used NAPA JV100 which is 1/16" thick I think.If you make this one check the backlash of the cam gear. The LH cover and fan shaft ones need to be really thin shims and adjusted. Main bearing housing shouldn't matter within reason ? .010"-.020" one way or the other ? Get a couple different sizes and an old mic to take with you and you can match it up with the old.
Mike M
12-23-2007 10:33:13
 JV100 may be 1/32 in reply to Mike M, 12-23-2007 10:27:19
The more I think about it that very well could be less than 1/16" more like 1/32" ? I'd have to measure it. If you get some too thin you can always make 2 of them and stack em up.
Rudy in TX
12-23-2007 09:50:08
Our local auto parts sells 3 thickness of gasket material. If I was doing this I would use the thinest one they sell and use a little gasket maker-sealer. Just guessing but I think their thin gasket material is about 10 thousand thickness.
P Browning
12-23-2007 14:34:08
 Re: 52 B Gasket Thickness in reply to Rudy in TX, 12-23-2007 09:50:08
Gasket thickness in the John Deere Scheme of things is thin (1/64"), medium (1/32"), and thick (3/64"). For this appplication, I believe that I would opt for the medium thickness. Going with the thin gasket is too risky with these old castings which were never perfect to begin with. And if you have the 3/64" gasket material on hand, I think it is safe to run with it as well. In any case, I (also) would use a non-hardening gasket cement such as Permatex # 2 or # 3. (PatB)
F-I-T
12-23-2007 15:54:04
 Re: 52 B Gasket Thickness in reply to P Browning, 12-23-2007 14:34:08
I really think it was the "thin" material on the left main. I seem to remember that. I've got one for a late-styled "A" around here somewhere, but not sure if I can find it before you do the install, but as I recall, it was pretty flimsy. Greg Steven could probably tell you over the telephone as I think he makes those gaskets.
IMHO, One place on an old John Deere that is dimensionally dead true is main bearing flanges to the main case. I'm pretty sure that the case was machined by Blanchard grind on one side, then flipped over, and the other side was machined datum direct to the other side. The axis of the crank was most likely used from there to face the case where the block mounted (since this was critical to compression ratio etc.), as well as the 90* to 90* to 90* surface of the governor case, and then the rear to the tr4ansmission to rear end flange. After facing the main housings, those were either bolted to a fixture, or maybe even to the main case itself (doubtful given the need to allow for using a replacement part down the road), and align bored. Another way to guarantee for the main bearing carriers being really close to radial location and dimension is the design which allows for attachment of the mains to the case in only one predetermined position. Once machined to this index, it would always go together the same way. This is especially true in a diesel which has three mains.
Now on this "B", since the right hand main is inside the first reduction cover, there's no gasket there, right? A little Indian Head gasket shellac and nothing more on that surface.
If pressed to guess, I would have guessed that left side gasket was about the thickness of a match book cover. When we used that stock in the fields for setting points the old timers called a matchbook cover .018 to .020". It got many engines going again.
Maybe someone has one and can mike it, but it's pretty soft, so don't crank down too hard on the paper because if you do you can make it just about any thickness you like!
Hope you find the gasket in the size of stock that you need. It's tough getting a rebuild hung up on those simple items.
Frank
P Browning
12-23-2007 17:44:50
 Re: 52 B Gasket Thickness in reply to F-I-T, 12-23-2007 15:54:04
Frank -- It is at the right main bearing that gasket call-out is for a thin one with affectivity of B248810-up. (PatB)
P Browning
12-23-2007 17:51:05
 Re: 52 B Gasket Thickness in reply to P Browning, 12-23-2007 17:44:50
I could be amiss on that thin gasket implementation -- I can't seem to locate my reference at the moment. 'Sorry! (PatB)
F-I-T
12-23-2007 18:14:18
 Re: 52 B Gasket Thickness in reply to P Browning, 12-23-2007 17:51:05
third party image
Not sure where you got that serial number reference. Maybe I'm looking in the wrong place, but I thought he meant the gasket between the main bearing housing and the main case. My parts book (PC 330) shows the gasket, B 3026 R, on the left hand main, not the right, was the same used from the beginning at S/N 1,000 on up to end of production. I'm referring to the main bearing housing to main case gasket. Maybe I'm not understanding which gasket is in question, but even the whole engine gasket set is the same from 201,000 and up.
Frank
Maark
12-23-2007 06:57:28
Shouldn't make any difference as to the thickness.
