1020 electronic ignition
RLH
12-23-2007 04:10:25
Can you give me a good honest reptuable source for a electronic ignition for a 3cyl 1020 with prestolite distrubtor how hard are they to put in? thanks
machinery-man
12-23-2007 15:36:05
 Re: 1020 electronic ignition in reply to RLH, 12-23-2007 04:10:25
I"m a believer in electronic ignition...but don"t know about one for prestolite...I always preferred the delco....properly installed you shouldn"t have any problems with the electronic...hotter spark, easier starts....
jdemaris
12-23-2007 07:59:52
I'm not going to get into what's reliable, and what's not. I'll take the OEM points setup anyday.
That being said, that engine is very common and I'm sure Petronix makes the kit. Same engine is used in 350 crawlers, 380 forklifts, 300 industrial tractors, etc.
John T
12-23-2007 10:27:33
 Re: 1020 electronic ignition in reply to jdemaris, 12-23-2007 07:59:52
Gee jd, Now I see why we BOTH love our ancient Vacum Tube radios lol. An elec switch is good when its working n I preach on their ability (WHEN working) buttttt if they crap out youre dead in the water versus being able to file the points n get back to the shop.....
John T
jdemaris
12-23-2007 10:52:07
 Re: 1020 electronic ignition in reply to John T, 12-23-2007 10:27:33
I agree 100 %. I've seen electronic conversions come and go since the early 1960s. New companies keep coming and going. A few years down the road, you're usually screwed. That never happens with conventional ignition parts. If you can't buy something, you can make it.
Petronix seems to be a popular one now - but with the dealers I've checked with near me - none stock replacement parts. At least with a car or truck, those parts are mass-produced and can be bought almost anywhere.
I've had to deal with several, not very old engines that parts can no longer be bought for the factory installed electronic igntion systems including a few Stihl chainsaws from the late 70s, and some Tecumseh cast-iron 10 horse engines with a convoluted Phelon breakerless system that barely worked when new. Now, the only answer is - convert to good-old-fashioned breaker-point ignition. If I had to run a car or truck many miles, many days, at high RPMs, I might feel different. With tractors? I'll take the old style ignitions. Even old mags from the 1930s often just need the points scraped, magnets recharged and a new capacitor. All easy to find and/or do. Even if you need an impulse spring or a coil, you can always make do with something.
