B model yr. ?
mac7
12-22-2007 20:08:36
Is there anyway to identify the year of manuf. of my john deere b. The serial no. has rusted away. I was always told my Dad bought it new in 52, but have no way of knowing for sure. Any help would be great !!
Will P
12-23-2007 08:33:09
 Re: B model yr. ? in reply to mac7, 12-22-2007 20:08:36
Tag rusted away?? The only years that used a steel tag was late 42-44. I know you state that it was bought new in 52, but that would be an aluminum tag, they don"t rust away.
Will
jdhbag
12-23-2007 08:06:25
The rotor ventilator pump part # A4191r went in at SN B300867 Water pump went on at SN 306600. Hope this helps.
DJD-Man
12-23-2007 07:20:19
Square axle B was just before 251 ish. Agree with Kent. 49B's can have square axle. Agree with quadrant.
F-I-T
12-22-2007 20:40:43
Rear axle housing became square at S/N 201,000. Gear shift quadrant went from round to square at S/N 201,000. So if you have round axle housing and a round shift quadrant, it's before 'late '47 or what I generally call a '48, but I'm not a "B" guy. '52 was S/N 293,000 and up, according to my little yellow cheater card. At 260,518, the square shift quadrant became two piece, a top and a bottom. A nut to hold the brake drum on came in at 232,468.
Take a cruise through the PC-330 parts book and you'll see details that might get you closer like a change in the spark plug wire conduit, etc. I just paged to a few items that I thought might get you into a rough couple of year break.
Good luck!
Frank
Kent Petersen
12-23-2007 04:04:57
 Re: B model yr. ? in reply to F-I-T, 12-22-2007 20:40:43
Frank the rear axel was square on 1950 and above but some late 1949 prod had them i have a late 49 b that is square it has been in the faimly sences the spring of 1950 thanks Kent
mac7
12-23-2007 13:22:44
 Re: B model yr. ? in reply to Kent Petersen, 12-23-2007 04:04:57
Thanks for the help. The serial no. tag is alum., but the no. is gone. I have square axle housings and square 6 speed shifter box. Thanks again..Mac
