950 down pressure
Tom/Idaho
12-22-2007 16:28:40
Does the 900 series, 3 cyl diesel have down pressure on the three point?
Thanks, Tom/Idaho
buickanddeere
12-25-2007 05:05:25
 Re: 950 down pressure in reply to Tom/Idaho, 12-22-2007 16:28:40
For posthole auger use. Sometimes a great hulking spring gets added to the three point hitch.
Mark - IN.
12-25-2007 20:21:58
 Re: 950 down pressure in reply to buickanddeere, 12-25-2007 05:05:25
I've been lucky to never have a problem with an auger. A few times started to bite or catch a root and cork screw down instead of bore, but have always been lucky to catch it and lift out before got myself into trouble, then ease back down at a slower rate. Thats using a 12" auger.
Texasmark
12-25-2007 15:05:42
Yeah, the great hulking spring is the 250# fat kid from the next farm over hanging on the guide arm on the digger.
Mark
buickanddeere
12-25-2007 21:01:32
 Re: 950 down pressure in reply to Texasmark, 12-25-2007 15:05:42
Personally adding down pressure to a posthole auger is a dismembered body just waiting to happen. That's why I like the header spring from an old swather.
Texasmark
12-23-2007 07:14:30
You can't put down pressure on the 3 pt, especially on 2wd tractors as you could lift the drive tires off the ground.....seems reasonable.
Mark
MSM
12-22-2007 23:07:09
No, it's gravity down.
Mark - IN.
12-24-2007 20:45:57
 Re: 950 down pressure in reply to MSM, 12-22-2007 23:07:09
Correct.
