JD 40 Utility
Mark Manezes
12-22-2007 14:27:23
My 40 has 95# of cylinder pressure and some blow by. I am the fourth owner and don't believe the engine has ever been overhauled. The person I bought it from knew it's history from the time it was new. I would like to raise the hp to 28-30. Are there higher compression pistons available for the 40 and possibly a hotter cam. Has anyone done anything like this to a 40 and if so, what were the steps taken. Any information would be greatly appreciated. Thank you.
CPeter
12-22-2007 16:28:30
 Re: JD 40 Utility in reply to delta bob, 12-22-2007 14:27:23
Remember it has thermosyphon cooling, no water pump, so if you hop it too much you may have cooling problems.
CPeter
Mike M
12-22-2007 15:47:18
 Re: JD 40 Utility in reply to Mark Manezes, 12-22-2007 14:27:23
Just a good complete overhaul may give you alot more than you have now ?
I have heard of someone who bored a 40 out to accept 420 pistons,but I don't know how it worked out in real life ? Like power or if it gave any overheating problems.
Mark Manezes
12-22-2007 16:18:46
 Re: JD 40 Utility in reply to Mike M, 12-22-2007 15:47:18
Thanks Mike for your reply. Probably will end up giving it a standard overhaul but I am still interested in hearing if anyone has hopped one up. Mark
4020LP
12-22-2007 19:04:07
 Re: JD 40 Utility in reply to Mark Manezes, 12-22-2007 16:18:46
You can hop them up, to a degree, but there's not much point, because if you're going to pull it, the ring and pinion won't stand it for very long, and if you're going to use it in the field it will overheat. Been there, done that. If you want more power, sell it and buy something more powerful.
