borrowed it and broke it
Lou
12-21-2007 09:53:37
Borrowed a JD 4500 with loader to move some snow. As I stood up to get off I steped on a round black nob with a turtle on it, and broke it off. I would like to order a new one on line.
As always thanks for the help.
Lou
12-22-2007 09:07:36
 Re: borrowed it and broke it in reply to Lou, 12-21-2007 09:53:37
Thanks gentlemen , Im off to get one.
machinery-man
12-22-2007 04:46:19
Lou: I would tell the owner and let him repair and pay the bill. This way if anything comes up you've leveled with him and no hard feelings. I remember some time ago one of my club members borrowed a tool and tried to fix it and then it didn't work and the other member knew he damaged but didn't say anything about it. Hard feelings....
Wayne_H
12-21-2007 17:51:37
I have a 4400, the baby brother to that machine. I think that knob you are talking about determines the rate of drop for the rock shaft/3PTH. Not critical, I am sure Dr. Deere can get you a new knob in a day or two.
Wayne
F-I-T
12-21-2007 10:29:35
You can go to JDParts.com and see an illustrated parts manual for the 4500. If you can describe where the knob is located, tell me if the tractor has a hydrostatic transmission, left side rear of platform, front side, right corner, up high, down low, what you think the knob is for, etc., and I can probably get it down to a part number for you. I'm not imeediately familiar with the 4500. I have an 855 and there is a high and low range selector lever on the lower right rear behind your knee coming out from the transmission which is used to select the high (rabbit) or low (turtle) ground speed range. I think on the 4500 this lever comes out pretty high, so I'm not sure if this is what you are referring to.
Frank
Lou
12-21-2007 10:40:56
 Re: borrowed it and broke it in reply to F-I-T, 12-21-2007 10:29:35
This is a round nob ,which is located about dead center between your legs when sitting on the tractor. Has a picture of an arrow pointing down tword a turtle. This nobis made to be twisted or turned for speed control of some kind.
F-I-T
12-21-2007 10:48:25
 Re: borrowed it and broke it in reply to Lou, 12-21-2007 10:40:56
Is the knob in front of your and between your legs, or under your butt so that is runs something to the rear? Is it a gear tranny or a hydro?
Any of you 4500 owners jump in here.....
Lou
12-21-2007 11:31:00
 Re: borrowed it and broke it in reply to F-I-T, 12-21-2007 10:48:25
I am guessing its a hydro, it had a shifter lever on the left side of the steering colum. 4WD nice tractor.
F-I-T
12-21-2007 12:03:22
 Re: borrowed it and broke it in reply to Lou, 12-21-2007 11:31:00
If you make it move forward or aft by pressing on pedals on the right deck instead of releasing a clutch pedal on the left side it's likely a hydro. I'll go see what I can find. Wish I knew what the knob did. Maybe it's a rate-of-drop knob for the three point hitch.
F-I-T
12-21-2007 14:03:34
 Could it be this?... in reply to F-I-T, 12-21-2007 12:03:22
Three point hitch rate of drop knob?
third party image
