H Governor-Fanshaft Bevel Gears
Walter Squires
12-21-2007 07:52:02
I'm going to reassemble the governor and fan shaft this weekend and of course when I took everything apart to clean, bead blast and prime it I didn't mark anything, I have all new bearings and felts but the problem is the bevel gears are pretty pitted and not from a matched set, I feel very confident I can set the heel and backlash OK but am I making a big mistake not having a matched set of those expensive little jewels. I have a copy of Pat Browning's "The Governor" which is very well written and easy to comprehend and I'll use it a guide. By the way I received the gauges from Evergreen and they are absolutely beautiful.
Mike M
12-21-2007 15:03:51
 Re: H Governor-Fanshaft Bevel Gears in reply to Walter Squires, 12-21-2007 07:52:02
Of course you could always just pay the piper, grin and bear it and bite the bullet and get the new ones from JD and then you won't have to wonder about them.
F-I-T
12-21-2007 09:28:08
Walter:
New gears are available, so it's your call if you choose not to spend that money. That said, if you choose to re-op the old gears, you need to really evaluate what you have as far a gears go, and remember, they all started out as unmateched sets, not being matched until they were installed into the governor housing at the factory. They were all hobbed on the same machine. The concern might be the pitting, as pits tend to act as tiny teeth and can actually grow as they erode and chew parent metal as the hours go by. "H" governors were not known for their copious oil flow either.
I have rejuvenated old and odd paired sets by powering them in the housing and letting them work their way back into a paired shape. Here's a clip from an older post that describes what it is that I do.
>>>When I was rebuilding my 70D I found that of all the gears still offered by JD, the set for the 70/720/730D's were not available new. I mounted my gears on an arbor, and while turning, took down the "tips" of both gears with a grinder so that the length of the teeth were a bit shorter than the depth of the mating gear node or trough. Radius the tips accordingly as well for a nice blend that will not chew. I also watched the relative tooth pitch (width or thickness) as compared to the pitch of the node. Since this tractor was a power steering model, the fan shaft bearings are mounted in a block that is only 3 1/2" thick or so, with a stub shaft protruding. I mounted this stub in my drill press, with the governor case attached, set the gears to a good state of rubbing and sat there while it turned, oiling a squirt at a time. Then I removed a shim or two on each side, and ran it some more. After several sessions, I was able to check the contact area using some Prussian Blue dye just as you would set a differential ring gear and pinion. Once the contact area was back in the normal zone, I set the heel and lash again on the low side and ran the set for an hour under an oil drip. At the end of the hour, I gained only a couple of .0001"s (1/10,000th) so I called it good. After installation, the gears ran quiet, the stub shaft play was quite minimal, much like the manual suggested, and they continue to run very quiet to this day. The key was dressing off the tips of the teeth that can cause interference, which I believe, is where the majority of the noise comes from when someone tightens up an old set. Using this method I have successfully re-paired many used sets that I think would have been tossed. I never saw the need to use lapping compound as the gears seem to erode each other fast enough as it is.
I did fab a fixture to hold non-power steering type fanshafts and use an old 1/2 hp electric motor to turn it. A combination of sheaves keeps the speed at a safe level.>>>
HTH.
Frank
Walter Squires
12-21-2007 13:07:31
 Re: H Governor-Fanshaft Bevel Gears in reply to F-I-T, 12-21-2007 09:28:08
These gears do not show hardly any wear their just pitted real bad, maybe I should look for a better set, so far I have a real good feeling how everything is going back together so I hate to compromise a complete restoration at this point.
I could bronze the pits up and file them but would that really accomplish anything since the bronze is fairly soft?
F-I-T
12-21-2007 13:35:57
 Re: H Governor-Fanshaft Bevel Gears in reply to Walter Squires, 12-21-2007 13:07:31
Walter, I think that that would make it look nice for a bit, but it has a good chance of eroding pretty fast. Any chance you can post a picture? I mean there are pits, and then there are PITS! Soft edges or sharp edges capable of cutting the mating gear surface? If you grit blast them before you re-wring them, you might soften the edges of the pits up enough to allow them to just blend in. Years ago we had an important gear set from an old Buffalo mill that had pits, but no replacements available, so we spray welded the pitted areas and re-ground the gear faces on our articulated cutter grinder. Then we did the re-wring until they set in well, and it was nearly impossible to see where the pits were. SO, you can get pretty elegant with the fix if you wish.
Mike M
12-21-2007 09:49:01
Frank; I have yet not needed to do a set of gears that way,but my old AG Mech. instructor ex. JD mech. used to run some in that way. I do think he did use some kinda grinding compound ? maybe to speed up this process ?
F-I-T
12-21-2007 10:18:57
 Re: H Governor-Fanshaft Bevel Gears in reply to Mike M, 12-21-2007 09:49:01
You can use lapping compound, but it gets every where and if you are using the case for the fixture, getting it all out of there can be tedious. I find that if I use time as my ally, I get a good finish and I only have to worry about washing out the metal powder that the oil filter would catch anyway. I don't like the thought of grit in the governor bearings. If you do use lapping compound, a quality oil based type like one of the Clover SC grades is best. Use coarse grit to get close then the really fine grit for a polish. The same grades we used to use to polish high finish forging dies.
I've done this for many years. I think I re-opted my first set 40 years ago. I've re-opted ring and pinion sets this way as well. It will really quite down a noisy gear box, too if you have a method of closing up the clearances for the wring in, then can reduce the gap via thrust settigns or shims afterward. You are just after re-establishing a formed contact area, not removing each and every pit.
Frank
John T
12-21-2007 08:52:25
Walter, do as you like buttttt ttttt if I had a governor down and only wanted to work on it ONCE Id be afraid NOT to uSe a matched set of gears EVEN IF a used set..... if I didnt wannA spend the bucks for a new set. Of course that means finding a used matched set out of the same governor that arent so worn you can shave with them (like so many out there). I neglected the governor weight pins in mine grrrrr rrr
I may be over reacting cuz if you set the heel n backlash they will work but Id just prefer a MATCHED SET. Im afraid of whine n noise and an un matches set just not running as smooth????
If the experts show me wrong so be it lol this is just how id do it
John T
