JD 40 oil filter
Fred Mills
12-20-2007 19:08:10
Could someone describe how to replace the oil filter on a 1954 JD 40 standard.There is a disc with attached spring that I'm not sure how to install.
Thanks.
Fred Mills
12-21-2007 06:21:42
 Re: JD 40 oil filter in reply to Fred Mills, 12-20-2007 19:08:10
Thank you all for your help.
Fred
fatbob50
12-20-2007 20:38:23
There are two washers inside the filter. One is up inside the filter with a spring on it. That usually stays up inside even when you take it apart. The other one goes on the other side of the filter. A lot of times when people change the filters, they throw away these washers without knowing it. That washer needs to be on that filter. If it is not there, your filter will not work properly. You should get someone to post a diagram of it, or a picture, so you can see how it works. It would help if you had an owners manual. It has pictures of this. Email me if you need further assistance. Regards, Bob
Wayne in Tn.
12-20-2007 20:25:57
The spring and plate should stay with the filter housing when removed. Also there is a big washer that should stay in the bottom of the filter mount. Usually these are gone and will not matter with todays filters with the metal ends.
Rusty Wheel
12-20-2007 20:22:28
The book on my 40 is out in the shop and it's late but I believe the spring goes in the bottom with the disc up against the filter. I'll look at the book tomorrow and if this is wrong, I will reply again..... ..... RW
