Hello,Two parts: 1st - If anyone has a brass 3 way gas valve, and it starts to bind up in some places, and seems too loose in other places, I found a simple fix. Remove the valve from the tractor, and take it apart. Clean the stem and the plug as well as you can using Scotchbrite pads. Put the stem in the chuck of a lathe with the plug pointing outward. Coat the plug with 500 grit Fel-pro Clover Compound, turn on the lathe to about 500 RPM, and place the valve body onto the plug. Apply enough pressure to let the compound do its work. After a minute or so, clean the compound out, and apply 1200 grit Clover Compound. Run this the same way for a minute or two. After you are finished, clean the valve thoroughly with solvent. You should be quite pleased with the way the valve feels when finished. (If anyone wants to do this, but doesn't have the stuff to do it, you can send your valve to me, and I will do it for the price of return postage.) 2nd - Does anybody have an extra brass nut that holds the valve handle and plug into the valve body? It measures about 1-1/8" across the flats. I have checked my normal sources, and haven't found one yet. Thank you, Greg
