630 Water Pump Impeller
GlenT
12-20-2007 09:29:44
I am having the pump rebuilt and the impeller is grooved. Does anyone know how much can be taken off to get rid of the groove or better yet, what the final minimum thickness can be to ensure there is enough spring tension so the pump won't leak? Does anyone know a source for a new impeller is? I have a new seal, ball bearing (shaft), and spring retainer.
JD dealer wants $127 for a new pump, or $100 for the impeller. So, rather than spend $100 for the impeller, I'd go for the new pump but my first choice would be a new, cheaper than $100 impeller.
Thanks
GlenT
12-22-2007 05:13:26
 Re: 630 Water Pump Impeller in reply to GlenT, 12-20-2007 09:29:44
The part number for the impeller is A5319R.
Kevin Meier
12-20-2007 14:38:57
Depends on what seal you are using. Most spring seals need .035 spring pressure to operate plus most john deere pumps should have a .025 gap between the fins and the casting. When I rebuild those pumps I use a unitized seal, which requires boring the pump and machining the impeller. If ya have any questions feel free to email me.
Kevin
Mike M
12-20-2007 10:22:54
I have faced many of them down. You can just press it onto the shaft a little farther to keep the spring tighter. If yours requires alot off or if it was done before ? no way of knowing then maybe you may get some trouble with water flow if it gets too thin ? I wish I would of measured new ones and wrote it down for future referance. I have done this on alot of other things,but I don't think I did it on impellers. I did have trouble with reusing one once it didn't press back on the shaft tight enough and worked back letting it leak.
mike francis
12-27-2007 15:29:15
 Re: 630 Water Pump Impeller in reply to Mike M, 12-20-2007 10:22:54
i take them to machine shop, have them machine a countersunk hole that i install porcelin (spelling) washer like 4020 pump takes then seal runs againist the washer and u can replace it later with new washer
