2940 hyd.
larry burris
12-20-2007 08:53:32
got a 2940 and 3 pt. jerks and wont stay in position wants to go all the way up or down,also pto stops under load. Any thoughts on whats wrong. Thanks
MSM
12-20-2007 23:23:34
 Re: 2940 hyd. in reply to larry burris, 12-20-2007 08:53:32
You probably have an internal hydraulic leak on the rockshaft housing or valve. This bleeds off charge pressure which is used to apply the pto clutch.The longer you run it this way will burn up the pto clutches.
jd2140
12-20-2007 13:22:08
DOES THE PTO WORK OK TO BEING WITH BUT WHEN YOU SAY BUSHHOG IN TALL GRASS OR SPREADING A BIG PILE OR MANURE ITS LIKE YOU CUT IT OFF? IF SO SOUNDS LIKE YOUR PTO CLUTCHES ARE WORN OUT, I HAVE A JD CAB TRACTOR THAT HAD THIS PROBLEM, I JUST SPENT OVER $2000 ON IT AND REBUILDING THE LIFT. YOUR LIFT MIGHT BE WORE OUT AS WELL, ESP IT JERKING, IF YOUR OIL LEVEL IS OK IT IS PROBABLY LEAKING IN THE LIFT HOUSING AND NOT GETTING SUFFICENT OIL BACK THERE TO MAKE THE LIFT WORK PROPERTLY. iF YOU GET THIS ALL FIXED AND THE TRACTOR HAS A HI LO SHIFTER, CHECK IT WHILE YOUR IN THERE, IT HAS CLUTCHES ON IT TOO AND WHILE YOU HAEV IT ALL APART, ITS A GOOD IDEA TO SEE HOW WORN IT IS. THE MORE YOU USE IT THE WORSE IT'LL GET, IF ITS LIKE MINE THERE IS A PTO CLUTCH HOUSING BACK IN THERE AND IF IT GETS SCARED YOU'LL HAVE TO REPLACE IT AND AT $1500 ITS NOT CHEAP.
