39 B bearing on fan shaft
squezon
12-20-2007 07:50:41
The front bearing is noisy. I filled it with oil like the manual said and it ran out the back. So I took the plug out and put a grease zirk on it which helped. but is still noisy. I am afraid the bearing will come to pieces if I dont change it.
Was wondering how much of a job it is to change
patsdeere
12-20-2007 10:25:50
 Re: 39 B bearing on fan shaft in reply to squezon, 12-20-2007 07:50:41
I just did one on a 46 B and I found it to be a royal PITA. To get to the spring I had to melt out the 2 friction plates that squish against the fan (since they had rusted themselves to the shaft quite well). After I got the top plate off the fan blade came off easy. Then as I started to melt the bottom plate away the spring decided to help and threw chunks of the plate across the garage (so watch out if you do it this way). After that it was easy since the spring came out, washers came out and then the bearing.
Since you already have it torn apart you might want to check the bearing at the back end of the fan shaft too (since you don't want to do this again). I had a heck of a time getting the gear that meshes with the govenor off. I finally got it once it was red hot, had a pulley puller on it and an impact wrench. It took about 10 minutes of impact wrench to get it off. The thing glowed red for about 5-10 minutes (darn hot). Pull the shaft out the back of the tube and take the old bearing off. I found I had to cut part of it off since it is essentially pressed on.
Reverse the process to put it back together. I found it a little easier to put it together and then put the grease in the front spring area (through the little hole) since I had to keep taking it on and off since we had problems getting it together.
Even afer hanging on the fan blade (all 230 lbs of me) it was all that the guy who was helping me could do to get the keepers in (took a good couple of whacks with a hammer). It is something I hope to never have to do again.
I found the bearing to be expensive, but the cheaper at mother deere than anywhere else around me (~$45 each). You will probably also want to replace the felt packing up front by the fan.
Enjoy! :)
