For Clooney 51 B Clutch noise
DonM
10-12-2003 16:55:28
My clutch is making the pinging sound when engaged. I am sure it is the bolts hitting the dust cover. I read in another post this is a common prolbem on some B's. How do you suggest fixing it? I am planning on puting new plates in it as I have it apart now. Do you gring off the bolts a little or what?
Thanks Don
Clooney
10-12-2003 17:37:51
 Re: For Clooney 51 B Clutch noise in reply to DonM, 10-12-2003 16:55:28
Don, try the new plates but if the bolts are hitting the cover there is probably wear on something. Like the pivots, adjusting bolts, pivot pins, or pulley pin bosses.
~If the clutch works good & snaps in & out good you can just grind the ends of the bolts..
