All weather electrical switch?
Nylon4020
12-19-2007 19:54:23
Adding a forward and rearward light on the rops of my 790. There is a connector for rear lights already in the harness on both sides at the rear. Trouble is that they will come on with all the other lights. I want to switch both lights independently ( one switch each side) so that I only click them on when I need them. Anyway, Wondering if they make all weather switches as I can recall ever seeing anything. I know a regular toggle would work but curious.
Should add that I know that headlights will have to be on to provide juice to the switches.
John T
12-20-2007 06:55:27
 Re: All weather electrical switch? in reply to Nylon4020, 12-19-2007 19:54:23
The little rubber booty covers shown below work pretty good. I still use silicone where I can to seal out water and try n have the switch mounted at locations and angles so water drips away and use lil drip loops as necessary where wires connect.
John T
Bob
12-19-2007 19:58:26
Working tractor, NO "correct Police", RIGHT?
Simply drill a hole in each light for a toggle switch, and put a rubber boot over the "bat handle". About $2.50 for the boot.
Third Party Image
Nylon4020
12-20-2007 22:55:11
 Re: All weather electrical switch? in reply to Bob, 12-19-2007 19:58:26
Great info guys Thanks!
