Cleaning and Preserving Origional Paint
Jack B
12-19-2007 04:50:31
I purchased the "GP" that is a great running,. complete Tractor still in its origional working clothes. Any hints on how to best clean and preserve the remaining origional paint. I plan to show and use it as it is. Thanks!
sodly
12-20-2007 07:08:39
 Re: Cleaning and Preserving Origional Paint in reply to almrm, 12-19-2007 04:50:31
Beats me. Why would you say "I pollute the earth by pouring oil all over my plows outside" if that's not what you meant? Anyway, I hope it all ends up on the plows and not the ground, too.
sodly
12-19-2007 13:02:49
 Re: Cleaning and Preserving Origional Paint in reply to Larry Kastenss, 12-19-2007 04:50:31
I hope you're kidding about pouring oil all over your plows (and the ground). If not, the EPA would like to have a word with you. I believe the fine for dumping used oil is quite large. But even if no one ever catches you dumping oil, the guilt of ruining our ground water should be enough to make you stop. The used oil from one oil change can contaminate 1 million gallons of fresh water - a years' supply for 50 people. If you want to put it on your plow, please wipe it on.. don't dump it on.
Sorry for the rant but this is indefensible behavior.
RobMD
12-19-2007 19:27:23
 Re: Cleaning and Preserving Origional Paint in reply to sodly, 12-19-2007 13:02:49
when i said i pour it on the plow, I want that oil on the plow, not the ground. Why would I want rust-preventing oil on the ground?
Mike M
12-19-2007 18:24:40
Then the EPA needs to stake out the local Autozone stores as their parking lot is filled with oil from dripping junk cars that park there.
RobMD
12-19-2007 09:07:58
 Re: Cleaning and Preserving Origional Paint in reply to Jack B, 12-19-2007 04:50:31
used engine oil and a paintbrush. Then wipe off the excess. Makes it last forever.
Every time I change the oil in my cars, I pollute the earth by pouring oil all over my plows outside.
chrisfromsolitude
12-19-2007 07:04:19
There is a linseed oil mixture you can put on it to preserve it. I can't think of what you mix with it though. Pretty sure it was just something to thin down the oil to spray it on. Good luck.
dandeere
12-19-2007 05:52:47
Hi Jack, I am with you 100% they are only origional once. It will show if you take care of her without all the make up; use, maintain, and enjoy. I would just keep her under cover; its made it 90 years now! Dan
