Pistons for a JD B
Ben Rauls
12-18-2007 16:39:24
Looking for a set of .090 over pistons for a JD B. 1944, serial#156000. i've tried all the places i know of. No luck, found a guy that will make a set buy alot of $$$. Where would you look? Everything is back ordered (pistons for B serial number 96000-201000) with no expected date
What would you do.
Ben
Mike M
12-21-2007 06:54:53
 Re: Pistons for a JD B in reply to Ben Rauls, 12-18-2007 16:39:24
Didn't know if you saw my reply at tractor talk so here it is again.
Alot of those tractors can be bored out enough to accept the late 4 11/16 " gas pistons unless you hit a sand/rust hole or casting flaw ? These piston can be found used pretty cheap and you will really wake up your power !
greenmisterg
12-19-2007 14:52:38
Couldn't you sleeve it? Just asking///
Ben Rauls
12-19-2007 15:49:12
 Re: Pistons for a JD B in reply to greenmisterg, 12-19-2007 14:52:38
Thats what i might end up doing
Ben
machinery-man
12-19-2007 08:59:39
I would think these would be aluminum. Ever think about another block standard or 45 over where you could use original cast. Those should be available...personally never liked the aluminum pistons and rings as block has to be carefully bored for adequate clearance. I would say you should be able to locate a good block and pistons rather reasonable....
Ben Rauls
12-19-2007 14:43:12
 Re: Pistons for a JD B in reply to machinery-man, 12-19-2007 08:59:39
This is my second block, had some pits, took .090 to get the rust pits out
Ivan in Mich
12-18-2007 17:35:02
Mine is a 51 or 52 I don't remember for sure with out looking it up.
Ben Rauls
12-18-2007 17:36:25
 Re: Pistons for a JD B in reply to Ivan in Mich, 12-18-2007 17:35:02
yeah thats to late, 47 is the cut off i think
teddy52food
12-18-2007 17:24:33
Is it a 4 1/2 inch or 4 11/16 bore? I have a set for a 4 11/16 but the top ring groove needs to be worked on.
Ben Rauls
12-18-2007 17:28:34
 Re: Pistons for a JD B in reply to teddy52food, 12-18-2007 17:24:33
4.1/2"
Ivan in Mich
12-18-2007 17:20:27
I have a set for a late model B. I bought them but did not use them. Make me an offer.
Andy Motteberg
12-18-2007 17:22:32
 Re: Pistons for a JD B in reply to Ivan in Mich, 12-18-2007 17:20:27
They will not work from a late B. He needs ones for a early B.
Ben Rauls
12-18-2007 17:22:19
Mines not a late model, if your serial number is 201000 or later there bigger than what i need.
What year is your b?
Ben
