46 B being ornery
patsdeere
12-18-2007 13:48:33
I have a B thats start great but doesn't want to run on anything but about 1/2 choke. Somebody suggested taking the carb apart to make sure it is clean. I did and I could almost eat off the inside.
Next suggested possible problem was an air leak at the manifold. How in the world do you test for something like that? I really don't want to have to take the fan, radiator, upper water pipe, wire loom and such off unless I absolutely have to.
Thanks.
patsdeere
12-19-2007 16:23:00
 Re: 46 B being ornery in reply to patsdeere, 12-18-2007 13:48:33
I was just reading some other posts and was wondering if the govenor could be my problem. I didn't rip it all apart when I redid the thing.
John T
12-18-2007 15:27:01
Pat, they can be clean enough to eat in places you can see buttttt ttttt ttt the idle passages underneath the brass drill plugs and the area around the brass nozzle and the nozzle itself can be completely clogged and no amount of cleaning or boiling or acid dip till the cows come home will clean them. You have to remove all the brass drill plugs and remove the nozzle if you want to reallyyyyy yyyy clean the carb.
As far as a vacuum leak thats worse at idle and a way to find one is to spray WD 40 or carb cleaner etc around the carb especially the throttle shaft bushings and gasket etc and if she speeds up or smoothes out you found the leak.
If you do a search this topic of carb cleaning n idle passages n pulling a nozzle has been covered a ga zillion times
John T
patsdeere
12-18-2007 16:07:16
 Re: 46 B being ornery in reply to John T, 12-18-2007 15:27:01
I know and that is why I was asking for more ideas. I had the thing professionally redone and I know the thing was a disaster to start with and it came back looking like new. However, since everybody still things its that I will take another shot at it this weekend and see what happens.
DanL-Colorado B36320
12-18-2007 15:09:04
My late father, and my late grandfather before him, both mechanics their entire lives, used to preach to me that 90% of all fuel problems are ignition related.
A rich mixture lights much easier than a perfect or a lean mix. Weak sparks can cause this sort of trouble.
P Browning
12-18-2007 14:46:41
Pat -- there is a no-wrench test you can run on that carburetor to see once and for all if the IDLE passageway is open. Go tothe JD-H Restoration Site (below) and scan across to ARTICLES 1. From the drop-downs, select CARBURETORS. On the last page of that piece you will find the test. Clean enough to eat off of is not the right criteria. (PatB)
J. Wondergem
12-18-2007 14:34:05
To check for a vacuum Leak. Take a hose with one end up to your ear while it's running, place the other end around any place that might leak, like the carbuator throat.
machinery-man
12-18-2007 13:57:22
Sounds like your carb passages are blocked. You need to properly clean it. That should be a DLTX34 and I'm finishing up one for my brother-in-law now. All the ports have to be property cleaned.
