JD 1010 HP??
Dominic Centonz
12-18-2007 09:52:34
How much horsepower does a JD 1010 have? THANKS!!
jdemaris
12-19-2007 05:50:33
 Re: JD 1010 HP?? in reply to Dominic Centonze, 12-18-2007 09:52:34
I don't believe the posted horsepower specs for the 1010 gas engines. We never had one on a dyno that put out the advertised HP and we tested a lot of them. We got more power with the 1010 diesels with a little tweaking, since they have bigger engines.
1010 gas has just about the same size engine as the older 420, 430, and 440 two-cylinder engines - and has just a hair more power. If you were to believe the specs, a 1010 is just a little under the power of a 1020 - and in reality, a 1020 will work circles around it.
I regard the gas 1010s as 33 horsepower tractors, at best. A Case engine around the same time was rated a max of 33 horsepower with 148 cubic inches. An Allis Chalmers 149 c.i. gasser was rated 33 max horsepower. An IH 143 gasser at 36 horse. A 134 c.i. Ferguson at 29 horse. Yet, the smaller 115 c.i. 1010 was rated more?
4020LP
12-18-2007 12:59:44
 Re: JD 1010 HP?? in reply to HeyPigFarmer, 12-18-2007 12:12:48
Yeah, and some of it's even close to correct, sorry to say, at least about JD's.
Brian Bell
12-18-2007 10:04:45
36 at the PTO 30 on the drawbar.
