Advice on Pony Rebuild
woodvue
12-17-2007 20:06:17
I am in the process of rebuilding a 720 pony motor. I measured all the rod bearings with plastigage (I realize not the best method). The service manual says if the measurement EXCEEDS 0.005 to replace the rods. The measurements I took were all at 0.005 but not more. Do I need to do something to this bottom end to tighten up those measurements or should I reassemble with those rods? The rods and journals looked to be in good shape.
Thanks
Steven
F-I-T
12-18-2007 07:16:42
 Re: Advice on Pony Rebuild in reply to woodvue, 12-17-2007 20:06:17
You really need to know if the crank rod journals are out of round and where the .005" in the rod bore is occurring. You can polish those cranks a bit to remove some of the out-of-round. A thou here and there and you're in business. You can steal a bit on rod clearance by judicious application of a light file or time on a lapping plate to the rod caps to bring in the top and bottom play. Time to sit with someone who has the right measuring tools and you'll have a better bottom end and you'll likely avoid spending considerable dollars on some pretty expensive pony parts. Some of the pony cranks twist over the years so you might want to check for that while you are there.
Frank
Mike M
12-18-2007 04:17:41
I would check with a mic. Those rods can be resized some to reduce the clearance and reused.
Gerald J.
12-17-2007 20:52:41
Use a C clamp or dial caliper to find the worn diameter on the cranks and put the plastigage there to see the maximum clearance. Judge by that.
Gerald J.
buickanddeere
12-17-2007 20:42:36
Should be fine with a good quality engine oil. Don't forget to install new water pump seals. The oil drain back hole from each cylinder head has to be clean.
