5300 bogs down under a load
Brent Germany
12-17-2007 16:34:56
I have a 5300 with less than 1,000 hours and it has been well mainitained. However, the tractor began bogging down for no apparent reason, then got so it wouldn't start. Had fuel filter replaced and it ran okay for an hour then started bogging down under a light load or driving up an incline. . . John Deere mechanics then installed a new injector pump, which made it run better, but it still bogs down under a load and going up inclines. The only response I get from the mechanics it that it runs better than most of the other tractors on their lot. . . Go figure. Does anyone have any thoughts on this matter? I would appreciate your help.
RobMD
12-17-2007 19:55:59
 Re: 5300 bogs down under a load in reply to Brent Germany, 12-17-2007 16:34:56
look in the air intake. any obstructions and dirt in the filter/hoses?
You sure you're not overloading the tractor?
LarrySTN
12-17-2007 17:38:18
The only real way to know if it deficent in power is to put it on a dynamometer. Find a shop that will give it a horsepower check. It is possible that you still have a fuel restriction. Diesel fuel can grow a bacteria which will clog filters and screens quickly.
F-I-T
12-18-2007 13:02:27
 Re: 5300 bogs down under a load in reply to LarrySTN, 12-17-2007 17:38:18
I like the idea of putting it on a dyno. I have one and provides no truer test of perfromance. Unhook the return line from the pump to the tank as this can sometimes affect performance if it is clogged. Tank vent plugged? I have a dyno if you're near Tallahassee.
Frank
