JD Rod Bearings
Robert
02-03-2000 13:42:33
O.K. this is a fairly simplistic question but the manual I'm using is rather vague. Where are the rod bearings most easily accessed on an unstyled B for servicing, or removal of the pistons?
george
02-04-2000 13:43:00
 Re: JD Rod Bearings in reply to Robert, 02-03-2000 13:42:33
something you need to know, unstyled B's have babitted bearings. You will just have to remove shims to set the clearance.
clooney
02-03-2000 15:55:01
Robert, there is a cover (crankcase cover)on top of the main case, it is about even with the crankshaft. Just remove the bolts and remove the cover to access the rod bearings. If your manual does not show you this, you should get a better manual before you tear into it. Robert, if you are going to measure rod bearing clearence make sure you measure it at the tightest spot or you will end up with the bearings too tight (john deere cranks usually wear out of round on the rod journals)
