Belt Pulley Brake Lining
Walter Squires
12-17-2007 08:06:37
I need the pulley brake lining for the H but I don't want to use the new style that clamps over brake foot I would rather have the old style that rivets on, anyone sell these with the rivets?
CalJim
12-17-2007 21:32:11
 Re: Belt Pulley Brake Lining in reply to Walter Squires, 12-17-2007 08:06:37
There are lots of them on Ebay
Paul from MI
12-17-2007 13:53:37
You may be able to find some bulk brake lining material and rivets at McMaster-Carr or at an automotive brake shop that's been around a long time. The only andvantage to the clip-ons is they are easy to install. Don't look good and rivet heads nearly exposed when new, let alone after some use. Good luck,
Paul
Mike M
12-17-2007 09:21:47
I have even pulled the lining off the clip on type and used JB weld to bond it to the arm.Gives alot longer wear and the rivets can't dig in. You just have to sandblast the arm to get it clean enough for it to stick. I really perfer to use a thicker lining like drag line brake bands are made from. Getting hard to find,but my uncle had some I used.
F-I-T
12-17-2007 13:35:34
 Re: Belt Pulley Brake Lining in reply to Mike M, 12-17-2007 09:21:47
Mike:
If you want a really bonding agent for those linings, try a fresh bottle of urethane glue like they use on wood projects. It penetrates the lining's fibers and really bonds to steel, though the rougher, the better. I glue the lining in place, and follow up with rivets the next day. sure is easier to manage when you know the lining is stuck tight.
I have used it to re-bond two cylinder clutch facings to the steel holder, and I have not had one fail yet. It pays to clamp it in place, and mask everything off as it foams as it encounters humidity, and as it foams and cures it will get everywhere. Just stand back until it sets over night. Shave the excess off with a sharp knife or razor blade.
Frank
P Browning
12-17-2007 08:41:19
My dealer page (jdparts) shows only the clip-on assembly -- not lining & rivets. If you want to purchase just the H360R lining and D1592R rivets to go with it, and then install into the pulley brake arm -- call Heartland Tractor Parts (816) 587-4747 and talk with either Mel or Russ. (PatB)
RalphinWI
12-17-2007 08:27:26
I bought some are the dealer last summer.
RalphinWI
12-17-2007 08:26:51
