1010 crawler track and clutch
rrlund
12-17-2007 07:30:40
I posted this on the crawler forum,but I'll put it on here too. I usually only work on wheel tractors but things are slow. I've got a request to free up a stuck left track clutch on a 1010 crawler. As far as I can see I'll have to take the track off. Any suggestions? Master link? Dos and don'ts? I haven't said I'd do it yet.
sparepartsTN
12-17-2007 18:49:57
 Re: 1010 crawler track and clutch in reply to rrlund, 12-17-2007 07:30:40
Well if you have some strong shop equipment getting dusty, this will give it a workout. I sold mine 3 yrs ago but have a service manual here. Six pages of instructions that must be followed exactly (thats what it says). Clutch and brake adjustment can be made by removing top cover, anything more and you need to pull the master link to break the track, remove sprocket, remove six bolts to remove the final drive, make a "u" shaped lifting device from 1/2" steel rod to lift it away while pivoting it to clear bottom track rail. The clutch pack is inside the final drive housing. That is just an overview, not intended to discourage you, it will take time and probably a helper (everything is heavy). I can scan and email the pages to you if it helps. There are two different sets of instructions according to serial number: 0-31000, 31001 and up.
Let me know if I can help, Warren.
J Schwiebert
12-17-2007 09:48:17
Rick: Don't laugh, but do send me an e-mail. J.
rrlund
12-17-2007 10:27:59
 Re: 1010 crawler track and clutch in reply to J Schwiebert, 12-17-2007 09:48:17
OK,I think I've got your address. I must be nuts if I take this on,but I've gotta get out in the shop and DO something. It's only December,it's gonna be a long winter.
