5403 Second Question
crybaby
12-17-2007 06:46:13
I appreciate the answers before, but I wanted to add a little info. The 3010 we only use with a hog carrier on the back to haul pigs from one place to the other. Could possibly use it for some other light 3 point work. We have a couple of 4020's that start easy in the winter, but this 3010 just cannot be made to start. Have had the pump worked on, the engine was overhauled not very long ago, good charging system, etc. Just tired of fighting it. My main question is will the 5403 3 cylinder diesel stand up to everyday light to medium use? Thanks again for your replies and thoughts.
wilamayb
12-17-2007 07:24:38
 Re: 5403 Second Question in reply to crybaby, 12-17-2007 06:46:13
Sure it will. I just think you may find the whole tractor to be a little "dinky" You may be more satisfied with the Mexican built 05 series.
That 3010 can be made to start. You may have to spend just a few dollars, but if you will remove that cylinder head, install new valves and seats, have yours starter worked, install good batteries with big cables. Install a destroke kit on your hydraulic pump.
You can make it where it will start!! You can do all this work for less than $1000.00 That means you can take the other $19,000 and put it in a Roth IRA. You'll be amazed at what it will yield in 30 years. It just doesnt work out on paper to buy a new utility tractor.
If it's all about the want then go for it! If it's about need I feel that you can fix that 3010.
