810 plow bracket
machinery-man
12-17-2007 05:05:05
had a breakthrough looking for plow parts...my brother-in-law happened to have a JD plow and it appears to be a 810 per archive photos but now I wonder what I have. His has the upright support for center top link, but my plow has a triangle support and I think was developed for the quick hitch unit. I gained a gauge wheel and a rear wheel and bracket but the rear support shafts are lighter than the one on my plow. Also the angle of bend is opposite. I looks like John Deere beefed this up on the later model. The rest of the plow appears the same. My question is what model is my plow? Any photos as I would like to see the tail bracket. The one I have had a rim but no tire. Was this a solid tire or inflatable tire? Would like to have the correct tail bracket if available. Any photos would be appreciated.
LittleD
12-17-2007 05:55:09
 Re: 810 plow bracket in reply to machinery-man, 12-17-2007 05:05:05
I would say you have a 810A series plow because of the A-frame configuration of the mast plates. They went to this design because of the tendancy of the older 800 series plows mast to bend when the plow hit something. The 800 series plows used with the (50, 60 and 70 tractors).....such as 812, 813, 814 indicated the number of bottoms. Using these plows and tractors required the use of a gauge wheel to maintain the depth of plowing. While using the 20 or 30 series tractor with the load control feature no gauge wheel is used. The 810 series plow had no indication of number of bottoms in the model number....and because they were designed for the 20 and 30 series tractor had no gauge wheel. Rich,(LittleD)
machinery-man
12-17-2007 06:36:22
 Re: 810 plow bracket in reply to LittleD, 12-17-2007 05:55:09
makes a lot of sense...I can see why the A frame, and I suppose they went to the rubber tire for road use for tractors with lighter hydraulics, ie. I"m sure the old JD"s 20-30 series would have held it up but other make tractor may have not. Interesting....and I suppose they beefed up the tail wheel tractor for road use and sturdier field use. Interesting. I know these are much heavier plows than the 45 series, I suppose JD didn"t spare any steel back the late 50"s when they were breaking into the 3 point market.
