Q1 - Yes, according to Parts Catalog PC304, page 18, the affectivity of the foot throttle pedal is H1000-up. Q2 - This is from the John Deere "H" Restoration Guide, 2nd Ed. " THE SEAT -- Owners of early styled JD tractors often debate the number of holes are to be found in the AD1606R pan seat for a given production year tractor. According to Two Cylinder Magazine, this seat was used on all styled tractors (until the battery box seat), but the number of holes changed over time! From the beginning in 1939, until some time in late 1941 production, the seat had 9 holes. Then it was changed to a 7-hole pattern that held through most of 1944 production. Beginning with 1945 you should expect to see 5 holes. It appears a 3-hole decision was implemented by late 1946, and continued into 1947 when this seat was phased out. Q3 - According to PC304, the upper water hose is B406R and the lower is B402R. The air cleaner hose part number is H140R. Then go to the JD-H Restoration Site (below), scan over to ARTICLES 2, and then from the drop-downs, select HOSE CHART. On page 2 of the hose chart piece, see that B402R is of stock R32654 and is 4-inches long; B406R is also of stock R32654 but is 6-inches long; and finally -- H140R is of stock R32649 and is 2-3/4-inches long. Now, going back to page one of the hose chart, see that R32649 stock is stick hose with ID of 1-3/4-inches and OD of 2-1/8-inches; and that R32654 stock is stick hose with ID of 2-3/8-inches and OD of 2-3/4-inches. Now -- at another stop over at the JD-H Restoration Site, under ARTICLES 1, you can learn which books and manuals are most helpful for you in working your H tractor, and see how to acquire them. I wish you well. (PatB)
