4020 Block Heater -Leave plugged in?
Joe in IN
12-16-2007 04:01:20
My 4020 that arrived this week has a JD Block Heater on it.
Do I only plug in when I need the tractor(well an hour or so before) or should/can I leave it plugged in?
It seems to get the water very hot so I am leaning towards only when I need the tractor.
Thanks
LarrySTN
12-16-2007 13:57:54
 Re: 4020 Block Heater -Leave plugged in? in reply to Joe in IN, 12-16-2007 04:01:20
Plug it in only as needed. If you choose a timer BESURE that you buy one rated at wattage with a rating greater than the wattage of your block heater. Most timmers are rated a 600 watts, if your 4020 has a typical tank type heater, it will use 1500 watts. Grossly overloading the timmer can be a fire hazard.
msb
12-16-2007 10:46:54
A programmable timer will soon pay for itself in your case.
Matt_In
12-16-2007 04:11:30
 Re: 4020 Block Heater -Leave plugged in? in reply to Maark, 12-16-2007 04:01:20
Unless you really want to give your power companies CEO a bonus, I would plug it in a couple hours before you need the tractor.
Gerald J.
12-16-2007 08:54:04
 Re: 4020 Block Heater -Leave plugged in? in reply to Matt_In, 12-16-2007 04:11:30
Only if its diesel. My gas 4020 has a block heater. I've not needed it yet with a good battery and charging system.
Gerald J.
