5020 engine
Texas Sand
12-15-2007 20:49:51
I just got a 5020 in nice shape, runs good. I hear a lot of bad stories on the engines in these machines. What is the problem, anything you can do to avoid a catastrophe? Signs to watch for? BTW, it has 4900 hours on it, Looks and seems to be right, but was overhauled 200-300 hours ago, but I don't know the reason why. Thanks
MSM
12-16-2007 05:45:18
 Re: 5020 engine in reply to Texas Sand, 12-15-2007 20:49:51
The main problem was the oil pump drive gear. It is driven off off the cam,and the thrust load on the gear would cause it to wear as well as the oil pump housing, and the thrust collar on the cam.It would eventually wear to the point where the gear would fail or the gears wouldn't mesh,or wear out the thrust collar,letting the cam move causing a loss of oil pressure. The wear was accelerated by poor maintenance,and heavy thick oil. Other problems were caused by the addition of turbos and over fueling,and then being lugged down.I have seen 5020's with a stress crack starting at the block deck on #1 cylinder and going down behind the starter.
