1949 B Gauges
OL-TIMER
12-15-2007 10:35:09
I was woundering if someone could show a picture of the dash so that i can install new gauges in proper place.
Pete in MD
12-15-2007 21:36:18
 Re: 1949 B Gauges in reply to OL-TIMER, 12-15-2007 10:35:09
Temp. gauge on the left.
Oil Pressure on the right.
Amp. on the bottom.
OL-TIMER
12-16-2007 04:47:09
 Re: 1949 B Gauges in reply to Pete in MD, 12-15-2007 21:36:18
Thanks Pete for the reply this was all cobbed up with aftermarket stuff. Also there is no switches of any kind.What is supposed to have?This is my first John and dont have one close to look at.
Pete in MD
12-16-2007 08:58:43
 Re: 1949 B Gauges in reply to OL-TIMER, 12-16-2007 04:47:09
A switch for the lights if it has them.
An ignition switch if it's been converted from a magneto to a battery ignition.
The hole in the lower right corner is for the shutter control rod.
The hole in the lower left corner is for the choke control rod.
P Browning
12-16-2007 05:13:03
Ol-Timer -- If you have not already attempted to acquire the manuals for your John Deere tractor, here is guidance for learning which ones apply and how to get them.
Go to the JD-H Restoration Site (below), scan over to ARTICLES 1, and of the drop-downs under that heading, select DEERE PUBS. Page 2 will tell you which Deere manuals go with your tractor, and on the bottom of page 1 are instructions for getting them. Welcome to John Deere's. (PatB)
