How bad have I messed up?
Mitchissippi
12-15-2007 10:28:55
I dropped one of the bolts that holds the starter on a 3 cyl 830, down into bellhousing.
It's actually a threaded rod about an inch long with a nut screwed about a 1/3 of the way down.
Reckon there is enough room in the bottom of the bellhousing case for that bolt to ride without binding up with the flywheel?
I sure hate to have to split the tractor just for that bolt, but I will if I have to.
Fumble-fingered Mitch
P Browning
12-16-2007 05:52:07
 Re: How bad have I messed up? in reply to Mitchissippi, 12-15-2007 10:28:55
One concept I didn't see here is to use a piece of ordinary garden hose with a cow magnet inserted into one end! (PatB)
Big Country IL
12-16-2007 05:43:26
I did something quite similar - dropped a bolt into the otherwise pristine transmission on my '44 B. Picked up a magnet on a bendable aluminum rod and a spring loaded/spring handled tool that reminds me of the kids game with the crane that takes money and lets them think they can pick up a teddy bear. Anyway...I fished the bolt out in a matter of minutes with the magnet (I did try the spring loaded tool for a while too). I'd imagine an auto parts store would have it or home improvement or look up "claw retriever" at McMaster...saved me from splitting my tractor!
Big_Roy
12-15-2007 15:40:45
My Dad gave me a magnet on about a 2 - 3 foot spring. Don't know where he got it, but it's one of the handiest tools I've got.
Mat W
12-15-2007 15:27:32
I have a magnet on a solid aluminum pole. It is about 2 feet long and you can almost tie it in knots. Works better than the telescoping ones since you can bend it into all kinds of places.
Jeff in TX
12-15-2007 12:43:04
It would not hurt to get it out. My 830 has one that has been in there for years. Doesnt hurt a thing.
Mike M
12-15-2007 11:30:03
No way would I risk leaving it in there ! Try fishing out like suggested.
donwisc
12-15-2007 10:44:55
Buy yourself a small telescoping magnet, bend it if you have to and try to fish it out. One of the handiest tools to have , every one has done this sooner or later. Good luck
bighead
12-15-2007 11:59:53
 Re: How bad have I messed up? in reply to donwisc, 12-15-2007 10:44:55
Buy a Craftsman telescoping magnet. I've fished a few parts out of nasty places with them over the years. You've got to be careful bending them, as the brass is a bit brittle (you just have to put small kinks in the segments)... but you can bend them a fair amount if you're careful.
And best of all, once you've fished the part out... you can take it back to Sears and get a new one.
Colsen
12-17-2007 20:43:36
 Re: How bad have I messed up? in reply to bighead, 12-15-2007 11:59:53
I dropen a lifter jam nut down a motorcycle engine and thought I was SOL but I took a 1/4 inch hose raped a sock around one end and shoved it in me shop vac and the other in the engine until I got it and all the other sludge and grime. My 2 cents. Don't risk it in there.
