BR steaming
Marty Z
12-15-2007 07:53:21
I Have 4 unstyled tractors- GP -D- AR- and this BR. The BR always steams out the radiator cap after about 1 mile down the road. Temp reads about 190. The other 3 don't steam like that. All 4 are filled with 50/50 antifreze. Should I be concerned or should I just shut up and keep adding water. Thanks
Marty Z
dandeere
12-15-2007 13:41:58
 Re: BR steaming in reply to Marty Z, 12-15-2007 07:53:21
If its get up to 190 going down the road in the winter somethings not right. Do you see any leaks,oil in rad, water in oil, or bubbles in rad when running at higher rpm? Could be cracked,plugged, misalined or blown head gasket. Dan
Rusty Wheel
12-15-2007 09:21:28
If the radiator core is partially plugged, there should be a noticeable difference in the temperature of the top of the radiator, and the return line at the bottom I would think. Is the radiator clean in front so the fan can pull sufficient air? Is the fan turning properly? Just a thought. You've probably already checked all that. Merry Christmas..... .....RW
Marty Z
12-15-2007 10:57:36
 Re: BR steaming in reply to Rusty Wheel, 12-15-2007 09:21:28
It's a restored tractor with a new radiator and hoses. I know that doesn't mean the radiator is not plugged But it's got all new fluids.
It also steamed a bunch when it was just filled with water for the summer.
Rusty Wheel
12-15-2007 11:40:55
 Re: BR steaming in reply to Marty Z, 12-15-2007 10:57:36
Soumds like something might be causing the engine to run hot and the radiator is doing all it can to cool it. What happens when you run it under a load? If it heats up just driving it down the road with no load, it probably wouldn't handls plowing. If it's running around 190 degrees, I wouldn't worry about it too much, as long as it doesn't boil over. Are you sure the temp gauge is right? I had a 35 B and it always steamed a little bit. I've always heard that it's better to run an engine a little too hot than too cold. If it's newly rebuilt, it could be that when the tractor heats up and clearances begin to change, something is getting tight. Good luck..... ..... RW
Marty Z
12-15-2007 22:10:08
 Re: BR steaming in reply to Rusty Wheel, 12-15-2007 11:40:55
Thanks for the replies. I was just wondering. The tractor is put away for the winter now but in the spring I think I will check the fluid with a real thermometer and see what I read. It has a new temp guage and I will make sure it reads correct. If it is running at 190 I can live with it. It runs real good but it just boils off water more than I would like. Never had it under a load. Still don't have more than 3 hrs on it after the rebuild and restoration.
Merry Christmas and thanks again.
Marty Z
Curtice Ohio
Paul from MI
12-15-2007 08:37:55
Might be a plugged radiator. Take off the rad cap when it's hot. You should see the coolant circulating at 190F. If not you may have a plugged rad core.
Paul
Paul from MI
12-15-2007 08:37:45
Paul
