466 JD connecting rods
DUCK BILL
12-14-2007 18:27:07
I have R71074 connecting rods with new pins and bushings , how tight do the pins fit it in the rod, and how is the best way to check. They have been fitted but i would like to know how lose or how tight they should be.
Roy Suomi
12-15-2007 10:12:29
 Re: 466 JD connecting rods in reply to DUCK BILL, 12-14-2007 18:27:07
I always have new bushings put into rods..Any rocking can result in the pistons touching the head from the looseness in the bushings..You're this far , do the bushings too..Check with light oil, pins should just push thru with very light pressure with your thumb..They will loosen up with use..I did 1 engine years ago with what I thought were acceptable clearances..When I took the head off again, I saw the imprint of the pistons in the carbon on the head...Part number and all....
teddy52food
12-15-2007 06:16:16
Most pin bushings are a clearance fit at one to three ten thousands. If they are pressure feed it is more. I think it is 3 to 5 ten thousands. What is the size of the pin? The bigger the pin , the more clearance is needed. It is best to take them to a machine shop to have them checked.
rexhellwig
12-14-2007 20:04:47
It seems like everyone has their preferences...
I like to fit them so that when the pin and finished bushing are completely clean and oiled, the pin will fall through the bushing slowly with it's own weight.
But that's really a little too picky. The main things to avoid are reusing a bad rod, bell mouthing or tapering the bushing, or the biggie...dirty assembly. Forget the various motor assembly greases. If clean engine oil won't work for you, it's already a lost cause.
DUCK BILL
12-14-2007 21:07:31
 Re: 466 JD connecting rods in reply to rexhellwig, 12-14-2007 20:04:47
these pins will rock in the bushing dry, i don't mind the pickyness, got alot of money in this motor so picky is good, thanks for your help
buickanddeere
12-15-2007 06:02:41
 Re: 466 JD connecting rods in reply to DUCK BILL, 12-14-2007 21:07:31
What was the motor's condition that required the rebuild?
DUCK BILL
12-15-2007 17:44:27
 Re: 466 JD connecting rods in reply to buickanddeere, 12-15-2007 06:02:41
i have already had new bushings put in and fitted, i just think they are to loose. The reason for overhaul is farmer ran it out of oil. these rod are not pressure fed bushings these oil thru little hole in top that get oil from i guess the jet in block . I ain't putthem in yet may get 6 more bushings and go to another machine shop. I jsut need to know how to measure clearance between pin and bushing thanks
Drew
12-15-2007 18:13:46
 Re: 466 JD connecting rods in reply to DUCK BILL, 12-15-2007 17:44:27
If you have new bushings put in and pin fitted, I would make sure they bore the pin ends instead of honing them to size. If they are honed, the hone will push off to the top because the rod is tapered and the center-to-center length will be too long.
To me, the best way to measure the clearence would be a dial bore guage to measure the pin bore and a micrometer to measure the pin. I understand the average person doesnt have this equipment but I would think a machine shop should be able to measure them for you for minimal cost.
