Governer Model M and MI
J. Mark Krcmari
12-14-2007 17:06:43
This message is a reply to an archived post by FIT on January 25, 2006 at 08:43:07.
The original subject was "Re: Governer Model 50".
I'm trying to correct a pulsing in the engine. The Service Manual shows a stop that is mounted on the on the fan bracket. Neither thr msnual nor my brain can conceive what the stop is for. A round of beers at Casey's on Paddy's day fot a plausible answer. I'm not sure if this stop has anything to do with the engine pulsing. I have just installed a new ball joint. Do I need to disassemble the entire governor?
CPeter
12-14-2007 17:55:44
 Re: Governer Model M and MI in reply to old timer in ohio, 12-14-2007 17:06:43
J. Mark Krcmarik said: (quoted from post at 21:06:43 12/14/07) This message is a reply to an archived post by FIT on January 25, 2006 at 08:43:07.
The stop is to prevent too much pressure on the throttle arem of the carb when putting the throttle arm in the idle position.
CPeter
