49 B connecting rod bearings
Mat W
12-14-2007 13:06:56
Where is the best place (good price / good quality) to get connecting rod bearings, and having asked, what is the way to make sure I get the correct size, I know I will have to use a caliper but do you check the shaft or the old bearing??? I have seen a few but can not figure out the sizing on them.
Dare Frost
12-16-2007 15:39:34
 Re: 49 B connecting rod bearings in reply to buickanddeere, 12-14-2007 13:06:56
Earl, do you have the spec for a 1935 A rod bearing journals on the crank? Please email me at [email protected] if you do. Thanks, Dare
Mat W
12-15-2007 15:23:51
 Re: 49 B connecting rod bearings in reply to Mat W, 12-14-2007 13:06:56
They are the insert bearings. The babet (sp) is warn on one side and since I have everything torn down I did not want to put it back together and ruin the crank. I will check the crank with a micrometer, The bearnings are marked with CLEVITE 77 on one side and 12 72 CB 469 P on the other side.
I will try the company. I do not want to get the wrong thing and cause problems. The pistons were .045 oversized so I know the tractor was worked on at one point in time. My Grandfather got the tractor in very early 50s and it was not worked on other than services until I tore it down and started restoring it a few years ago.
Thanks for the help.
ET
12-16-2007 05:13:23
 Re: 49 B connecting rod bearings in reply to Mat W, 12-15-2007 15:23:51
The 12 72 would be the date of manufacture for the bearing insert. I would guess the engine was rebuilt in the early to mid 70's and 50 rods installed with along with the block bored. If the bearings were undersized they wuold also have 010, 020, or 030 for the undersize. Use a micrometer or a good vernier caliper to measuer the journals. Make four measurements 2 side by side for taper, then two more side by side 90 degrees away for out of round and taper.
Andy Motteberg
12-14-2007 19:32:21
Yesterday's Tractors sells them.
Earl - IL
12-14-2007 14:58:18
Do you have the engine apart? Do you have a micrometer? I have crank spec. if you need. If you have insert bearings look on back side of bearing. What does it say? Earl In Illinois
P Browning
12-14-2007 13:42:04
If you would like to consult with an expert in this area -- a man right willing to share knowledge with you, give Russ a call at (816) 587-4747. This business is long-known as Paul's Rod & Bearing in a Kansas City suberb and to the man, every one I've talked with has come away very pleased. (PatB)
