Rear-wheel-adjusting pinion shaft
55 50
12-14-2007 08:50:55
I saw a 730 diesel that had a rear wheel width adjusting bolt (Service Manual term is pinion shaft) missing and the owner had purchased a new one from John Deere. The new bolt was longer with a snap ring groove at the outer end and the snap ring came with it.
Must be a design change by Deere. I wasn't aware that those bolts would fall out on their own. I thought they were press fit. Has anyone else lost those shafts?
Mike M
12-14-2007 09:20:14
 Re: Rear-wheel-adjusting pinion shaft in reply to 55 50, 12-14-2007 08:50:55
I think I had one fall out,but found it in the drive. After you clean them up and get everything freed up they don't fit as tight. I had to take a punch or chisel and knurl the shaft to make it fit tight again.
F-I-T
12-14-2007 09:50:26
 Re: Rear-wheel-adjusting pinion shaft in reply to Mike M, 12-14-2007 09:20:14
The last one I bought from Deere was in 2001 or '02, and it was just like the original in the 70D, but that doesn't mean that they didn't later consolidate spare parts around a universal type replacement pinion shaft. I know like Mike said, when everything was cleaned up, the new pinion gear did not want to sit on the new shaft real tight, so I put two little puddles of Mig bead on there, and filed them down until they had just a nice interference. You do know that on the end of the pinion shaft, opposite the head, there's supposed to be a factory cork plug installed so water doesn't infiltrate?
Frank
