Implement Help????
Brian Nilesen
02-02-2000 21:00:56
I just got a Quick-Tach front and rear mount cultivator for my John Deere model B, and I am looking for some pictures and parts break down of this implement. Aditoinal help wanted. Thanks, Brian Nielsen
Chris Clouse
02-03-2000 21:16:46
 Re: Implement Help???? in reply to Brian Nilesen, 02-02-2000 21:00:56
Is that the same cultivator that you could put a been cutter on? Mounts on the frame of the tractor and four rods to the front then, if I remember right there is four 1 inch threaded rods that you attached the gangs toand you adjust them with the two nuts on each rod? The back cultivator mounts to the back of the axle housing I assume that you are eguipped with a rockshaft I think that what it called.(you hit the pedal underneath the seat with your foot)there is a special type of hook deal that you hook a chain from implement to those so that when you get to the end of the row you stop, step on the pedal,take it out gear,and engage clutch should raise disengage clutch put in gear let clutch out turn around and back down the field you go at least that the way a 45 A works. Hope it helps.
