720 LP vs. Gas/Diesel
utupuller
12-12-2007 16:40:46
why is a LP worth less than the others? Not being a collector myself, my opinion is, with JD's the rare tractors a worth more. Isn't this why the 80's are bringing 8,000 - 12,000 at auctions. If they only produced around 3600 of them, shouldn't the 720 LP be worth a little more since only around 3670 were produced?
4020LP
12-13-2007 14:02:11
 Re: 720 LP vs. Gas/Diesel in reply to utupuller, 12-12-2007 16:40:46
While I'm not a fan of pulling, here's something else that might interest you. LP has very high octane rating, so you can richen the mixture and bump the timing to get some really easy horsepower gains. I'd get it on a dyno, and play with the main jet settings and ignition timing. You'll find some extra power that won't cost you a dime, and is absolutely legal everywhere.
CLW
12-13-2007 07:34:44
 Re: 720 LP vs. Gas/Diesel in reply to mark, 12-12-2007 16:40:46
The LP engine will run very clean. Your oil stays clean. Fuel never goes bad in tank. Just a great tractor.
Like 4020LP says, most people are afraid of the fuel system because they were never around them. We used a new 60LP as a kid and had a B and a Ford 8N that were converted to LP. About half the tractors here in the 50s and early 60s were LPs. I can tell you that I don't recall any LP tractors burning up while being refueled, but do know of a couple gas tractors that did. Seems the gas cap was right above the plugs on most 2-cylinders and filling up in the field out of a 5 gal. can over a hot engine was an adventure.
RobMD
12-12-2007 21:41:16
comment below is dead on. Also, LP-gas 720 had one more horsepower over the diesel.
There's nothing like the torque of the diesel though.
4020LP
12-12-2007 17:00:40
A lot of people don't like LP-Gas tractors. They are afraid of them because of the pressurized fueling and special equipment required. Sometimess, production numbers don't make that much of a difference, a lot of it is what's "in' at the moment. People like the big diesel standard tractors, very few are fond of the LP-Gas tractors.Doesn't make much sense in light of the production numbers, but that's the way it is. Right now, in row-crops, anyway, LP-Gas tractors are often the bargain.
