B steering shaft again
Codie
12-12-2007 15:28:45
With the assistance of a pipe wrench I was able to turn the steering shaft and turn the gear free but now the shaft does not want to come out of the tractor. Now it will turn a little ways and come ahead and then spring back into the tractor. Now what should i do? Small pieces also chipped off the gear while I was turning the shaft with the wrench. Why were the gears so tight?
Andy Motteberg
12-12-2007 18:40:23
 Re: B steering shaft again in reply to Codie, 12-12-2007 15:28:45
I could not get the steering shaft out of our 1941 B once, I found the shaft was stuck on the bushing. I unbolted the small shaft support and worked the bushing out. I actually broke the one on ours and put on one with a worn hole so that the shaft goes in and out easily.
teddy52food
12-12-2007 17:20:26
As you are turning the shaft, tap the steering post back with a rubber hammer. The bushing is maybe too tight when it gets to the unworn shaft with paint on it.
Kurt_JDB
12-12-2007 16:09:50
Codie,
Something is majorly not right. The steering shaft should easily have turned out by hand. There is an eccentric bushing that adjusts how close the sector gear is to the worm. If this has been adjusted so that there is no play when the wheels are straight ahead (typicaly the most worn place on the worm) and now the wheels are turned, things can get very tight indeed. I would look into removing the screw that locks the bushing in place and try to rotate it so that things are not so tight. There is also a packing nut on the back side of the shaft which screws into the steering box. This should be loosened and backed off before you remove the shaft. There is also a bearing there.
If you do not have the B service manual, you need it. All this is covered.
Kurt
