4850 Oil Pressure Indicator
Howard H.
12-11-2007 21:25:47
Dad's 4850 dash oil pressure indicator is acting flaky. It jumps around randomly - especially at speed. It halfway works down around idle..
We plumbed a Murphy oil pressure gauge into the engine and the pressure is actually fine.
Any ideas on a common point of failure on the indicator? Sender? Dash? Relay along the way, maybe??
Thanks for any advice,
Howard
JMS/.MN
12-12-2007 09:27:09
 Re: 4850 Oil Pressure Indicator in reply to Howard H., 12-11-2007 21:25:47
Unhook the wire at the sender, touch it to ground, with the keyswitch on- it should peg the needle on the gauge. That means the sender is bad.
Texasmark
12-12-2007 06:27:47
Had a similar problem with a '74 4230 I bought fairly recently, but after I used it for awhile it settled down. I pretty much figured the sender had some sludge in it and it took some running for hot oil to flush things out that surely have been sitting around for many years with only 4000 orig hours.
Mark
JDBert
12-12-2007 06:07:26
 Re: 4850 Oil Pressure Indicator in reply to RobMD, 12-11-2007 21:25:47
Howard- my 4840 was doing the same thing- I replaced the sender on the right side of the motor and away it went.
