Looking in the early 4020 parts book, I'm not sure about both connections. One comes from a special bypass pipe (runs between the water pump and the thermostat manifold, there are two thermostats on the 4020) with a side spigot. The other hose goes to an elbow and a 4" long 3/4 pipe nipple. I don't know where that would go unless its something up top of the head. I don't think you will want the port on the water pump because the pump is cold water, unless that's a suction port on the pump. Hot water would be just below the thermostat. I'd be tempted to pull one of the hex plugs on the right side of the head and grab hot water there. That's where a tank heater puts hot water to the engine. Maybe one towards the rear and hook the other hose to a T added to the bypass pipe circuit. I've searched with google and found the question asked before without a good answer other than one suggsted the shop manual for the cabs would help. I know the early 4020 tractor shop manual is no help, I looked. I doubt looking a pictures of new generation tractors with cabs would help, because I've been around a few, even driven one or two and I don't remeber the heater hoses caught my attention. My 4020 has no cab and so no heater, but it has a tannk heater for the engine that takes cold water from the block drain on the left side and puts hot water to one of those plugs on the right side of the head. Gerald J.
