INITIAL START UP
JDNPC
12-11-2007 13:49:03
GOT ANOTHER QUESTION THATS BUGGING ME. I HAVE JUST TORE A 36' B ALL THE WAY DOWN TO THE NUTS AND BOLTS OVER THE PAST FEW MONTHS, AND NOW THAT SHE'S 99% BACK TOGETHER,I'M GOING TO ATTEMPT TO FIRE HER UP THIS WEEKEND. AS FAR AS THE OIL FILTER IS CONCERNED, SHOULD I LEAVE IT OUT FOR THE INITIAL START UP, OR PUT IT IN ? I WENT TO DEERE TODAY AND BOUGHT TWO OF THEM BUT I WASN'T SURE HOW THE ASSEMBLY LUBE WOULD DO IN THE FILTER. THANK YA..
jd b puller
12-11-2007 14:59:17
 Re: INITIAL START UP in reply to JDNPC, 12-11-2007 13:49:03
A little late now, but I would turn it over a bunch by hand with the rods Disconnected this lets the oil get "primed" in the system. THen I'd put the rods on it and finish putting it back together. Leave the spark plugs out and crank it over by hand. As long as everything feels fine, whip it over as fast as you can - This will finish getting the oil where it belongs. Then you're ready.
buck eye al
12-11-2007 14:25:49
I always use the filter.
I want it to back me up on my crank case clean out job by catching everything it possibly can. I also always hand crank them after I fill them with oil, (crankcase still open) until I see oil oozing from every reasonably visible point the lubrication system is plumbed to before I try to start them. May be overkill but I've (knock on wood) never ruined a new bearing yet.
bucke eye al
12-11-2007 14:27:21
 Re: INITIAL START UP in reply to buck eye al, 12-11-2007 14:25:49
Looks like Frank was answering the same way 'bout the same time.
F-I-T
12-11-2007 14:09:28
I would use the filter. The last thing you would want or need in those new bearings would be one spec of a shaving, or a slice from a gasket.
You can fill that filter by turning the engine over a couple of dozen times, maybe more, with the plugs out. Those pumps have pretty decent low speed output, so it should fill quickly.
Frank
