Hauling Model B with flat rear tires.
M. Poss
12-11-2007 10:11:33
I have recently bought a 1939 B that has round spoke rims with flat tires that wont hold air. I am afraid of hurting the rims if i load the tractor on a trailer with the flat tires. I would appreciate any suggestions. Thankyou.
James Howell
12-11-2007 20:11:48
 Re: Hauling Model B with flat rear tires. in reply to M. Poss, 12-11-2007 10:11:33
I bought �Lazarus� a 1940 B that had round spoke rims with flat tires that would not hold air.
third party image
No damage to the rear rims at all on his move to the farm.
Paid $600 for the wheels and got the tractor at no extra charge.
The wheels have been �spruced up� and are now on �John B� a 1943 B.
third party image
Good luck with your project.
Mike Aylward
12-11-2007 15:02:17
I would say that the loading process won't hurt the wheels as much as the trip home with it tied down and bouncing. If this bothers you simply jack up the rear end and put some blocks under the drawbar frame, then tie it down. This way you won't be putting pressure on the rims by the bouncing. But odds are as light as the tractor is you won't have to worry about it. Mike
Duane Larson
12-11-2007 14:53:52
M. Poss,
I agree with the other responses - if the rims are ok it won't hurt them and I doubt you will create more trouble even if they need work.
When you get it home, I would appreciate getting the casting numbers from the wheels, and their size, as round spokes on a '39B are a bit unusual. My email is [email protected]. Thanks!
James Howell
12-11-2007 20:20:49
 Re: Hauling Model B with flat rear tires. in reply to Duane Larson, 12-11-2007 14:53:52
Take a look at the metal tag on this factory round spoke wheel.
It is only on one of the wheels.
The tag reads "JD1270R".
third party image
This wheel came off "Lazarus" my 1940 B.
Will be on the farm in NE Texas for holidays.
Hope I can get a casting number for you.
Duane Larson
12-12-2007 09:31:34
 Re: Hauling Model B with flat rear tires. in reply to James Howell, 12-11-2007 20:20:49
James,
Thanks for the pix and info! Yes, that wheel is a replacement wheel that uses a bolt-in hub. The rim is likely 6.00S-36, with a 36" tire on it. The hub should be a B2188R (12 spline) and the hub clamp should be B2189R. I would be interested if there is any other casting information on the wheel itself - sometimes the JD1270R was cast in, and (I think) later the welded-in tag was used. Or, there could be other casting info - even near the wheel bolt plate where the hub attaches. If the tire and tube are off the rim, please look carefully on the inside where the tube rests - often rim information is stamped in there, like the rim manufacturer, the size, and often the date. That information would also be much appreciated!
I believe there was a round spoke wheel with a cast-in hub used early on the '39 styled B before Deere went to the flat spoke wheels, and that is what I'm wondering if is on the '39B I responded to.
I'm continuing to collect wheel info, and will be presenting a drop-in session on wheels at the Gathering of the Green in March .
jubilee johnny
12-11-2007 12:51:54
If it rolls ok on the trailer when you put the chain binders on it will stay better and more solid than soft tires.
Mike M
12-11-2007 10:17:46
I would not worry about the flat tires. What is left of the old ones may or may not come off ? but if they stay put they will help cushion the rims. Actually I had an unstyled B that had NO tire just a bare rim and even that was fine. I could even drive it around that way. Those tractors are not too heavy. If any damage will come it will be because of the rim being rusted and then it wasn't any good anyhow.
M. Poss
12-11-2007 10:39:42
 Re: Hauling Model B with flat rear tires. in reply to Mike M, 12-11-2007 10:17:46
One of the rims does have a hole in it i am not sure how big it is since i have not seen the tractor yet. The motor is not stuck and tractor is complete. I thought for 500$ i would take the chance. Thanks for your help.
RobMD
12-11-2007 16:38:34
 Re: Hauling Model B with flat rear tires. in reply to M. Poss, 12-11-2007 10:39:42
Sir, the round spokes are worth 500 bucks APIECE.
You did very well. I'd like to see pictures of it here. Good luck.
