48 B Compression Spec
C DC
12-10-2007 18:19:11
I did a compression test this evening my "48 B.
This was a "dry" test, and turned over by the starter for four revolutions (the gauge stopping increasing at that time). I have 93lbs on the left and 95lbs on the right. What is the ideal PSI? I"ve seen in the book where it says to be within 10 lbs for each side, but not the actual spec. One book says 80-150 lbs, seems like a wide range. The last time I ran the engine, it was more like Old Smokey than Johnny Popper. But, the spark plugs are a dry, black and powdery. If the compression is good, could the smokey engine be from running too rich, rather than an oil/ring problem, hence the dry plugs? The intake was absolutely clogged with mud dauber nests.
Thanks.
RobMD
12-10-2007 18:58:59
 Re: 48 B Compression Spec in reply to C DC, 12-10-2007 18:19:11
sounds like your tractor just needs some carb work. Blue smoke = buring oil. Black smoke = rich carb.
Don't worry about your rings for the moment.
Duane Larson
12-10-2007 18:51:53
C DC,
The only compression numbers given for the B are at "rated rpm", which requires the motor be driven at 1250 rpm (like belted up to another tractor). The rated rpm number is 110 psi for gas. For later models where both rated rpm and "motoring rpm", obtained from a starter with a fully charged battery, are given, the ratio of the two is roughly .8, which would translate to 88 psi. So, your compression meets specs in my book.
You have found a contributing problem to running rich, for sure. An obstruction-free air flow is a necessity. Lean out your carb as much as possible, and keep the operating temperature up as discussed in the owners manual.
