Is 50 front frame same as 520?
Eldon (WA)
12-10-2007 14:58:11
Is the front frame of a 50 the same as the frame on a 520? This is the part from the crankcase forward. Thanks
machinery-man
12-11-2007 08:00:30
 Re: Is 50 front frame same as 520? in reply to Eldon (WA), 12-10-2007 14:58:11
Well, the front frame would seldom be replaced and I"ve seen many of them laying around salvage...520/530 the same...however since they seldom are selling don"t let someone hold you up. I had one and hauled it off for scrap...there should be many but close by is what you need and the work to remove is timely and expense for a yard...I"d try to buy pedistal and all from case forward....they would boom that with no problem and all you have is 6 main bolts at case. Must be a pretty good weld to hold....
RobMD
12-10-2007 18:03:36
no, it's weird, but they have different hole locations, particularly for the spark plug caps, and uh, i beleive where the weights bolt up.
Eldon (WA)
12-10-2007 18:11:50
 Re: Is 50 front frame same as 520? in reply to RobMD, 12-10-2007 18:03:36
Thanks for the replies....I figured they were different since I read in a book that the 520's were new "from the ground up". Anyone have a 520 frame laying around? The one I have was actually broke in half right behind the front pedestal....someone did a good job brazing it back together, but I figure there should be a few out there in the boneyards. I would think a 530 would be the same....
RobMD
12-10-2007 19:07:42
 Re: Is 50 front frame same as 520? in reply to Eldon (WA), 12-10-2007 18:11:50
They are pretty much a different tractor. However, a 520 and a 530 is PRECISELY the same EXCEPT for a few obvious details with regard to the dash, steering shaft, hood, nosecone, and some electrical gadgets.
F-I-T
12-10-2007 18:08:33
Rod, you have sharp sight! Yeah, the spark plug covers had to move didn't they? The 520 moved the sparkplugs to the head, while the 50 had them in the block. They also introduced that three piece weight set on the -20's, too.
Frank
RobMD
12-10-2007 19:02:52
 Re: Is 50 front frame same as 520? in reply to F-I-T, 12-10-2007 18:08:33
wow! these new contacts must be working well, Frank! lol :)
4020LP
12-10-2007 16:55:35
No, it's not. Sorry.
bill mart
12-10-2007 15:38:16
parts book shows a different part number for model 50 vs. 520/530. bill m.
